Loganhorse
Jan 19, 2021Explorer
Adding Heat Strips
What's the chances of being able to add heat strips to a B57915.711C0 with a control box of 3107541.009. Having a hard time locating anything on it.
mobeewan wrote:Dometic makes a kit for the OP's model. I would hope it doesn't melt things.
Some A/C units have plastic parts in the area where the heat strip mounts that may melt.
road-runner wrote:mobeewan wrote:Dometic makes a kit for the OP's model. I would hope it doesn't melt things.
Dometic heat strip for B57915 ducted system
There's a different kit for non-ducted systems.
Two points from my experience:
1) Don't expect a huge amount of heat. Doug posted the wattage earlier. A space heater can give just as much or more heat.
2) These things stink like heck on the first use of the season. Before you really need it, run it a few minutes with the windows open.
Sjm9911 wrote:
I had them in my pop up ac. They basicly said they were more like warmers to make it a tad more confterble then to be able to give off any real heat. And they were right.
Lynnmor wrote:
Since heat strips put out about the same BTUs as a portable heater they will raise the overall temperature about the same. When people complain about little heat from them, they aren't considering the considerable air flow from the air conditioner fan. The air temperature from the ceiling vents will be much less than from a small portable heater but there will be much more air. That flow of air that is only a few degrees above the ambient air temperature may feel cool, but just leave it on. As the temperature rises it won't feel so cool when near normal room temperature.
way2roll wrote:
But to this point it begs the question - why bother? Given that it's considerably more cost and effort than a few ceramic heaters that produce the same result. Personally I wouldn't want to put the time and effort into a heating system that still leaves me feeling cold. I don't think I've ever read anything on this forum over the years that say that heat strips are awesome. Almost invariably, all posts agree, they marginally work if it's not really cold to begin with.
Because the cost is quite low, they don't need to be stored, they are always ready to go and a thermostat controls them. I have never seen anyone give them a chance to work, only instant gratification comments.
