Loganhorse
Jan 19, 2021Explorer
Adding Heat Strips
What's the chances of being able to add heat strips to a B57915.711C0 with a control box of 3107541.009. Having a hard time locating anything on it.
mobeewan wrote:Dometic makes a kit for the OP's model. I would hope it doesn't melt things.
Some A/C units have plastic parts in the area where the heat strip mounts that may melt.
cavie wrote:
If you add heat strips you must add wire and breaker to carry the extra load of the strips. Also, thermostat to control them. Not a DIY job.
cavie wrote:I don't understand why. There should already be a 20 amp circuit going to the air conditioner.
way2roll wrote:
I asked about adding heat strips to a former MH and was told that if your current unit isn't wired for it - with a harness, breaker, and thermostat- it wasn't an easy job or worth the time, trouble and money. Plug in ceramic heater will work just as well and be much cheaper and easier. That was sort of what I was thinking at the time and never bothered to research it much further so I ditched the idea.
