Not_a_Clue's avatar
Not_a_Clue
Adding Inverter
I know this has been discussed many times, but I am looking for information specific to my situation.
Currently I have no inverter in my motorhome.
I have two six volt batteries that are 7+ years old
I am not going to add more batteries, space issue......
I will be probably be changing them out for two AGM's
The easiest path to take is a whole house setup. Replace charger with inverter/charger.
Since this is being done at a shop the labor vs more expensive hardware kind of balances out.
I was quoted two ways to go.
Inverter....MSW 1200w 70A charger.
Inverter....PSW 1000w 50A charger $292 more.
I know that on this setup I will have to watch what I run and not run to many appliances together.
I will be going full time later this year. I am not looking for a setup for lots of boon docking, just looking
to be able to overnight in a non hook up environment if needed, or maybe a couple of days with out hook ups.
I have a good working generator. I have a Traveler automatic dish on the roof.
Based on lots of reading I am leaning towards the PSW, of course.
This will be an exact replacement to size also matters.
Thanks in advance!
  • PSW.. yes, get that. No problems running anything. Whole house? Yes, easiest by far. And don't trust those 7yo batteries to last much longer!
    It's a good idea for you to oversee the installation you want rather than one they want. They're just the labor, not the design. Don't let them scare you with stories about forgetting and leaving your WH on electric and running down your batteries. Of course you must remember to do that.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 14, 2025
