NinerBikes
Jun 22, 2015Explorer
SCVJeff wrote:
It's actually 12' by the time you make the full run. Personally I would run 4/0 to keep the balance of the batteries as close as possible, otherwise your remote stack will never charge to the same level as the ORM location, nor will it share the same discharge load as the OEM. The only way to fix that is reduce the line loss between the two locations, especially since these are all new batteries.
But that's just me..
/\ This, when dealing with DC current, the line loss needs to be calculated for both positive and negative wire run lengths totalled together.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
