pnichols
Jun 22, 2015Explorer II
Racorman wrote:
pnichols
Yikes...... I lost you in the translation
Would it be possible that you could use my numbered diagram to outline the connections. Such as: run cable from terminal 1 to terminal 4, etc
The hookup that smkettner is describing above is different than what I was trying to explain, but is also a balanced hookup done another way.
IMHO, I "think" that what I was explaining may have been a bit simpler. I like your 2nd diagram where you added the numbers!
Hookup everything as you had it originally diagramed, EXCEPT ... hook 10 to 2 (instead of 10 to 5 that you showed at first).
What a balanced hookup basically does is make sure all batteries age at the same rate - so they all wear out equally together. :)
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
