Racorman
Jun 22, 2015Explorer
pnichols wrote:Racorman wrote:
pnichols
Yikes...... I lost you in the translation
Would it be possible that you could use my numbered diagram to outline the connections. Such as: run cable from terminal 1 to terminal 4, etc
The hookup that smkettner is describing above is different than what I was trying to explain, but is also a balanced hookup done another way.
IMHO, I "think" that what I was explaining may have been a bit simpler. I like your 2nd diagram where you added the numbers!
Hookup everything as you had it originally diagramed, EXCEPT ... hook 10 to 2 (instead of 10 to 5 that you showed at first).
What a balanced hookup basically does is make sure all batteries age at the same rate - so they all wear out equally together. :)
In the original diagram I showed a cable from 2 hooked up to 5, with another short cable to 10....... so isn't that the same as you have outlined (10 to 2)?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 14, 2026
