time2roll
Jun 24, 2015Nomad
Ivylog wrote:Balanced in parallel the parallel cable will be half so 65 to 75 amps. Out of balance maybe just 35 to 50 amps. If series then it would be the full load 125 to 150 amps.
Doubt the OP's inverter will be a PSW so adding a small PSW inverter to power the CPAP is probably the best solution. Now that we know the max draw... coffee maker at 1500W or 125A and in a balanced system (IF you ever figure out 5 to 8, 7 to 9), what is the max AMPs on the 6' cable? Anyone, Anyone
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
