time2roll
Jun 29, 2015Nomad
Racorman wrote:The 6' jumper stays in place so the terminal is not empty.
If I do what you recommend:
"either 9 needs to go direct to 3" ......... battery terminal 8 will not have a cable on it?
"OR 10 needs to go direct to 2" ........ then battery terminal 5 will not have a cable on it?
What is the real downside of wiring it up the way I've shown. Would the "balance" be that bad to affect the life or power from the batteries?
If #10 is a frame ground only... just move the frame connection close to #2.
Otherwise the right hand batteries will wear out faster. Normal use at 20 amps or under it may not matter much. 150 amps into an inverter will matter a lot more.
