Remember, bulk/abs voltage is not full time 24/7, darkness shuts charging down a bit.
Try it for a week.
if/when i add another controller, i will
until then i could try a higher set on the float voltage, because the Xantrex will only only bulk for One Hour
then drop to float, so the only way is to raise the float setting
thats worth a try, think i'll change that tomorrow morning
the controller is in a storage bay, its about half way between the batteries and the panels i'll raise float to 14.1 and use it as a substitute absorb
