AndyfromTucson
Aug 12, 2015Explorer
kbehrent wrote:
Any recommendations for 100W panels and controller? Are they usually paired or do you buy the best panel for the money and than buy the controller separately?
As of last fall the best deal I found on 100 watt panels was Renogy panels on Amazon. Amazon also had a great selection of solar controllers at good prices.
You can use any controller with any panels as long as the voltage and amp specs are appropriate for each other. Look at the panels output voltage and amps and the controllers max voltage and amps. If you spend a few hours doing web research on solar systems you should be able to do it yourself if you are moderately handy.
