- wa8yxmExplorer IIII feed my TS-2000 off the house main 12 volt panel less than six feet away... No problems. Does not care if running on over 500 AH of lead acid battery or 80 amps of Progressive Dynamics or both.. It just puts out 100 watts. (Peak)on most bands.. Bit less on VHF/UHF by choice (Pressed POWER and turned know anti-clockwise then pressed POWER again choice).
- :R
- 2oldmanExplorer IIHe's pulling our chains.
- grizzzmanExplorerThere are dc to dc "chemistry" modules that would separate the charging voltages. So...... it could be done and other methods as well.
- NinerBikesExplorerI'm recovering from the Blue Marlin Fishing down at the Yacht Club down in Quartzsite, AZ.
- Searching_UtExplorerYou could do it, but if you're asking if it can be done you're probably not up to building the electronics you'd need to be successful. I haven't really looked, but doubt you'd find plug and play type control circuits.
- grizzzmanExplorer
Here is a link to a Chemistry module - GordonThreeExplorerNiner, can you post a link to the lithium batteries you're using? are they a "naked" battery back, or are they retrofit modules with a built in BMS / charge controller?
Just an off the cuff observation, but I don't think you'll have trouble charging a lithium pack as if it were an agm. Likely the agm charge voltage isn't high enough to fully charge the lithium, but that doesn't matter to a lithium. - Canadian_RainbiExplorer
NinerBikes wrote:
There's a dirty old man down in Mexico right now, choking from laughter on this thread. I can feel it, 1500 km's away.
Speaking of MW, where has he been. :h It's just too quiet on here.
We'll be driving up that way in a couple of weeks. Yes, again (different jeep though) :B
Maybe I should drop in and surprise him. - MrWizardModeratorIf it's April 1st, where is the spring weather
Did I sleep ALL winter, what happen to Feb and March
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
