mapguy
Jul 05, 2013Explorer
gdreese wrote:
Yes you can tap into that line by replacing the elbow with a T. You can get all the parts you need at any hardware store. Just remember it is a high pressure line. Ace hardware will cut and thread the pipe for you.
Agree, would suggest putting a shut-off valve at the tee for secondary tank supply input. Might consider using a hi-flow quick connect set for the flex line needed for a portable tank. Make sure any of the hardware/piping/fittings will pass the need amount of gas flow (btu's). No need for an additional regulator as you are plumbing into the high pressure side of the existing system. Use Pipe Dope not tape for best results. Make sure what ever sealant is used that it is rated for LPG usage. White water service tape is not usually rated for gas installs.
Take a look here for LPG quick connects.
http://mbsturgis.com/products/mb/rv-propane-hoses-sturgi-stays-quick-disconnects-regulators.html
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
