theoldwizard1
Jan 09, 2019Explorer II
wa8yxm wrote:
By the way there is a slight difference between most 12 volt (MARINE/deep cycle) and most 6V (Golf Car/DEEP CYCLE) batteries. the way I type it suggests.
MARINE/deep cycle you can safely use about 25% of the capacity. run 'em down to say 25% SOC and the odds of recovery are... SLim (not none but clearly slim)
DEEP CYCLE you can safely use 50%. Run 'em down to 25% SOC and odds are good they Will Recover (not 100% but way better than the MARINE type).
I would not call that a "slight difference" !
I happened to have had an email conversation with Trojan about this topic (The T-1275 is a true deep discharge 12V "golf cart" battery; The SCS225 is more of a "dual purpose" battery, one of the the few that Trojan actually lists "Cold Cranking Amps" for.)
James M. Cobb Technical Support Engineer Trojan Battery Company wrote:
The T-1275 is a higher capacity battery, rated at 150 Ah where the SCS225 is rated at 130 Ah. The T-1275 is a heavy duty 12V golf cart battery with thicker plates, which means it has a longer cycle life at 50% DOD, 1200 cycles versus 600 cycles for the SCS225.
Oh, the T-1275 weighs 85 lbs and the SCS225 weighs 66 lbs. The T-1275 is BCI Group size GC12 and the SCS225 is BCI Group Size 30H, so they are not physically the same exterior size.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
