Golden_HVAC
Nov 05, 2014Explorer
It is much better to use a couple of portable electric heaters. Find them at Wal Mart for $15 - $25. Don't get the heavy oil filled ones, they are - well large, heavy and have to heat up to work, then cool off before storing them to move the RV.
I like a fan type, test the fan at the store (they have plenty of places to plug in cleaning equipment in the store) to see if the fan is quiet. They are the most compact, and blow out heat in the safe 90 - 110F range.
The large cone "Infra-red" heaters can warm clothing to the point it can ignite (saw a demonstration as a kid, never forgot about it) and are 'large'. The tiny ceramic heaters that I have seen put out heat well above 120F and do not move a lot of air, so they are out as well.
I will run one 1,500 watt heater on high and the other on low heat output, so the first is about 12.5 amps, while the second is 7 amps, to keep the total well below my 30 amp rating.
Have fun camping!
Fred.
Have fun camping!
Fred.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
