mchero
Nov 06, 2014Explorer
Heat strip will supplement the Heat pump between 30 - 40 deg F. Anything below that & it will have to be Gas furnace or, in my case a small ceramic heater in the coach set at 40 deg and a 60W bulb in the heated basement. When I'm done for the winter (in about two weeks) I'll remove the perishables & winterize.
Deb & I are trying some winter camping this year.
Last weekend we stayed in an RV campground with just 30amp service. Woke up to about 35 degree temps & the heat pumps where not putting out much, if any heat.
The heat strips are about 40/pop & takes about 10 minutes to install. I'm not expecting to heat the coach with just the heat strips.
Thanks
Thanks
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
