MM49's avatar
MM49
Adjustable Battery Charger
•Temperature compensated with control limits
•SCR Regulation – Charger provides a constant current and constant voltage charge as well as an excellent AC line regulation for precise control.
•Selectable Float Voltage – Allows battery voltage to be precisely set to the battery manufacturer specifications, within 0.10 of a volt.
•Positive Voltage Setting – Select only the voltage setting. No other setting required. If preferred, voltage can be pre-set at the factory.
•External Temperature Probe – Charger will monitor the exact battery temperature, which prolongs battery life and reduces maintenance caused by excessive heat and water loss.
•Dual Input Voltage – Charger has been designed for either 115 or 230 volts AC.
•Transient Protection – AC input and DC output have surge protection
•Battery Types – All maintenance-free cells, lead acid cells, and nickel cadmium cells
Battery Charger
  • El Randero once tried to tell me 2 depleted group 31 plTP AGM batteries could not accept more than 75 amps, when a 100 amp model was ordered.
    When the real 100 amp 'boondocker' arrived, which was physically larger to boot, surprise! They could accept over 90amps, and could for close to an hour before tapering began.
    If I wanted smoke blown up my A$S I'd get a cigar and a garden hose.
    Trust if you want to, but believe only after verification.
    You want a Powermax, skip Randy, go right to Errin @PM, and tell him what Absorption voltage you want, if not 14.4.
    Dont try and ask for a digital timer though.
  • MEXICOWANDERER wrote:
    Look...
    MANUAL CHARGERS ONLY were successfully used for like nine decades with lead acid batteries.
    Jeez have mental powers actually degenerated to the point where folks need keepers?
    I am looking.
    Those chargers were not adjustable.
    And yes many folks DO need keepers.
    It is only partially about "mental powers".
    The other and possibly more important part is about training and experience. When you spend all of your free time in front of a TV or video game, that leaves little time to study and experience things that really matter.
    Look...
    I am looking.
    I can sum it up in 4 words. "You can't fix stupid".
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
