MM49's avatar
MM49
Adjustable Battery Charger
•Temperature compensated with control limits
•SCR Regulation – Charger provides a constant current and constant voltage charge as well as an excellent AC line regulation for precise control.
•Selectable Float Voltage – Allows battery voltage to be precisely set to the battery manufacturer specifications, within 0.10 of a volt.
•Positive Voltage Setting – Select only the voltage setting. No other setting required. If preferred, voltage can be pre-set at the factory.
•External Temperature Probe – Charger will monitor the exact battery temperature, which prolongs battery life and reduces maintenance caused by excessive heat and water loss.
•Dual Input Voltage – Charger has been designed for either 115 or 230 volts AC.
•Transient Protection – AC input and DC output have surge protection
•Battery Types – All maintenance-free cells, lead acid cells, and nickel cadmium cells
Battery Charger
  • A lot like a Rolls Royce ad.
    If you need to ask, you can't afford it. Bet the cheapest charger there is >$450 and a hundred twenty amp charger would be worth the same as a home living-room furniture ensemble. And I don't mean "You'll Love It At Leavitt" quality.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
