- SCVJeffExplorer
MEXICOWANDERER wrote:
POST
Tell me about LEDZILLA por favor...
Looks like a 3,000 Kelvin color temperature. Any available in 5,000 K? I assume this is a 60 watt lamp. Can't see the decimal point.
Since then I added a voltage regulator pre-dimmer that's dialed up to the max rated current for the LED''s when the dimmer is on full bright. - I have similar to run my model train at Christmas ;)
Sure regulates speed better when the voltage is perfectly regulated.
Amps and power increase up hills and drop when descending for a more constant speed than even my fancy controller that cost double.
No intention to use it to equalize a battery. - SCVJeffExplorer
you think that's an up converting switcher or just a wide range regulator? I have one advertised like that, but it's output was always ~.5v below the input, which was OK for the LED project at the time.
Heh Heh Heh
http://www.buyincoins.com/item/41034.html#.U4DcdyimUoN
http://www.buyincoins.com/item/45853.html#.U4DcdyimUoN - pnicholsExplorer IINow ... if only that little $59.95 beauty could deliver up to 60 or so amps right along with all of it's precise digital control of everything ... then the RV techies out there could really and endlessly tweak (unfortunately - manually) the charging profiles of their RV batteries. :C
- LScamperExplorer12V 100W led
http://www.youtube.com/watch?v=CxnP-6EZ3ZQ
Variable DC Power Supply 30v 5a
http://www.youtube.com/watch?v=4H6iwiPIaJI
High Power LED Forward Voltage Tutorial
http://www.youtube.com/watch?v=S5IICsTwTYE
305 DC LAB POWER SUPPLY REVIEW
http://www.youtube.com/watch?v=A3yZTSAd8YE - MEXICOWANDERERExplorerTell me about LEDZILLA por favor...
Looks like a 3,000 Kelvin color temperature. Any available in 5,000 K? I assume this is a 60 watt lamp. Can't see the decimal point. - SCVJeffExplorerLooks like mine and that's what I used for LEDZILLA . At $60, it's a steal because this one ran close to $300
- westendExplorerEqualizer-in-a-box! Going to check it out, thanks Mex!
- sh410Explorer
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
