MEXICOWANDERER's avatar
Aug 07, 2014
Adjustable Power Supply For Equalization
$92.00
0-30 volts adjustable with knob
0-10 amps adjustable with knob
Voltage and current displays
This is twice the amperage of the lab power supply I listed earlier. Suitable for almost automatic equalization of batteries to 240 ampere hours at a preset 16.0 volt limit, or dial it back to 8.0 volts to equalize a single golf car battery. It will work perfect for group 34. 27 an 29 12 volt RV batteries as well.
Big enough to test water pumps, refrigerators, lights, etc.
http://www.ebay.com/itm/30V-10AMP-10A-Precision-Lab-Digital-DC-Power-Supply-110-220V-Adjustable-Variable/121180217848?_trksid=p2045573.c100034.m2102&_trkparms=aid%3D555012%26algo%3DPW.MBE%26ao%3D1%26asc%3D20131003150253%26meid%3D8862884145978536192%26pid%3D100034%26prg%3D20131003150253%26rk%3D2%26rkt%3D8%26sd%3D151258287934
  • Bend wrote:
    See:
    http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27759727/srt/pa/pging/1/page/1.cfm
    CLICKY
  • Rolling Condo wrote:
    If I have an adjustable voltage charger (up to 20 volts) amperage limited to 10 amps. Would it work for equalizing a pair of 6V golf cart batteries and what voltage setting for how long?
    See:
  • If I have an adjustable voltage charger (up to 20 volts) amperage limited to 10 amps. Would it work for equalizing a pair of 6V golf cart batteries and what voltage setting for how long?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
