lawrosa
Apr 29, 2015Explorer
this is not the regular model with the charging profile that drops the voltage to 13.6 as soon as it gets battery to 14.6, so you would not want an Iota for that instead (which also drops its voltage but to 14.2, and the Iota is not power factor corrected )
The whole point of this one is that it gets the battery to the voltage you set yourself and it stays there forever until you change it. You have to do the charging profile yourself, but the point of that is you can pick any profile you like to match whatever your battery specification is. Using a timer for switching it off would be useful if you can't be there when it needs to be shut off.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
