jrnymn7
Apr 29, 2015Explorer
BFL,
I only use the converter as a charger... no 12v distribution. Anything needing 12v, (fridge controls, hydronic heat pump, for example), are run directly off the bank itself.
Are you suggesting I disconnect the bank from the charger for the initial 15 minutes, and then switch back on once voltage drops back down to my Abs setting?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
