jrnymn7
Apr 30, 2015Explorer
Well, I threw together a short 4ga pigtail, and installed a 50a switchable circuit breaker between the pm4b's positive output and the 2ga positive cable to the bank. I set Boost at 15.7v and Vabs at 14.7v. Resting ocv was at 12.72v.
I fired up the gennie, ran it for a few minutes on full throttle, then plugged in the pm, with the circuit breaker open. Then I turned on the eco, to save gas and reduce the noise. After the pm did it's 15 minute thing, I turned off the eco, and closed the circuit breaker.
Voltage dropped to about 14.3v, then quickly rose to about 14.6v, then started rising slowly from there. I then turned the eco back on. At last glance things were at about 8a @ 14.67v.
So everything seems normal.
