BFL13
Jun 27, 2015Explorer II
joelabq wrote:
Admittedly, I don't even know if there is a problem? I was just making note that this 100 appears to be identical top the one I'm sending back to Errin.
I can have him call, but I'm not sure this one won't produce the indicated amps.
Joel
If there is no such thing as an 8.5 inch 100, Errin will not need it tested for amps output.
Apparently there is a 100amper that does have only three fuses, which is confusing to me, but that still leaves the length. Your new 100 has four as do mine from a couple years ago. Must be a new model with three.
Anyway, do have him call as there may be more to it if it is another wrong sticker issue this time from a different supplier. It is important to return the old one if there will be a swap so they can poke over the old one.
Having RV issues? Connect with others who have been in your shoes.24,366 PostsLatest Activity: Mar 07, 2026
