JoeH's avatar
JoeH
Explorer III
Feb 05, 2015
Adjusting a Dometic Oasis Door Awning ????
Our Dometic Oasis electric door awning isn't going all the way in. I checked the manuals but they don't have instructions on adjusting the awning .... anyone have experience in adjusting the closure on one of these ?? Thanks
  • Sorry, after I thought about it a minute, I remembered you said DOOR
    awning. That is why I did the edit.
    I have had success in calling manufacturer's customer service lines direct to get info on how to do something. If someone doesn't come come up with a suggestion, maybe try the Dometic Cust. Service.
    Good Luck.
  • JoeH's avatar
    JoeH
    Explorer III
    Thanks-- but the door awning is a lot different. There are several set screws and potential adjustment points, but I would like to know the best way to get it adjusted
  • Is there a possibility you are over extending it? The valance (if you have one, if not, the ridge in the awning tube where you put hangers for lights)
    should be straight down.
    This happened to me and it would not close completely and going down the highway I thought it would literally come off the wall of the RV. Found out I
    was extending it too far, which kept it from closing up tightly. No problem since.
    On edit... I just read DOOR awning. Might not apply to that situation. Mine was the full awning.
