bass_n_bob's avatar
bass_n_bob
adjusting outside mirrors
the drivers side mirror won't adjust as far as I would like it to. There are 3 Allen head screws on the base. If I loosen them can I move the mirror without screwing up the wiring inside or the ability to adjust further from inside the coach?
THX
  • thanks for the fast response - I feel safer making the adjustments now.
  • They are designed so that you can do that. I loosened the screws on mine and adjusted them out a little bit so that I could see further out from the side of the coach. I can still adjust either direction from inside.
  • Yes, by loosening the Allens you can do major adjustments. Just don't go spinning the head.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
