- DEXTER NEV-R-ADJUST Trailer Brakes and How They Work
Busdriver wrote:
Trying to adjust my self adjusting brakes can’t find the star wheel through the hole, any idea
If they aren't adjusting by themselves, something is wrong with them it seems. - Old-BiscuitExplorer III
HappyKayakers wrote:
Roger10378 wrote:
enblethen wrote:
Haven't heard back from OP, whether talking truck or trailer.
His truck is new enough that it will have 4 wheel disc so the answer is trailer.
Not necessarily. My truck has 4 wheel disc brakes but the emergency brakes are drum and have the self adjusters on them.
OPs 1st post
Trailer brakes obviously cause truck parking brakes are NOT self-adjusting - HappyKayakersExplorer III
Not necessarily. My truck has 4 wheel disc brakes but the emergency brakes are drum and have the self adjusters on them. - Roger10378Explorer II
His truck is new enough that it will have 4 wheel disc so the answer is trailer. - Haven't heard back from OP, whether talking truck or trailer.
- wa8yxmExplorer IIII have. on occasion. had to pull the drum to find the Q@!#$!@#$ Star wheel.
A1B00902 wrote:
Used to in the old days, backup quickly and hit the brake hard,
Trailer self adjusting brakes do so when going/braking forward
As for Dexter Never Adjust......YES they can be manually adjusted
The Dexter Nev-R-Adjust electric trailer brakes can be manually adjusted. There are a couple teeth of the adjustment wheel that are exposed just under the lever
Attached is a photo showing the teeth. You will likely need a tool with a fine edge such as a flat head screw driver for the adjustment wheel on these brakes. A brake adjustment tool may be too thick.
- Grit_dogNavigator III
enblethen wrote:
Dexter never adjust has no manual adjustment.
Sure looks like there’s still a star wheel on never adjusts. But idk - A1B00902ExplorerUsed to in the old days, backup quickly and hit the brake hard,
- Dexter never adjust has no manual adjustment.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
