fourthclassC
Oct 19, 2016Explorer
Looks like steel framing to me. Regarding delamination, I suggest you use lexan of the same thickness as luan, with holes drilled randomly to enhance the grip. Then use gorrilla glue. I know this seems like out of the box thinking but I have repaired a great deal of delamination like that. With the gorrilla glue it must be clamped completely and I have used pieces of 2x4 as wedges and a cargo bar, against my barn wall. I have sealed corners (after removing aluminum molding) with Proflex then covered with eternabond (had to be cut to width) then re-screwed on the aluminium molding back on over the eternabond, with new stainless screws (Know as shutter screws in some places and they come with white painted heads)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
