Joe417
Oct 19, 2016Explorer
I've used the gorilla glue (polyurethane). It works great for attaching panels where the material prevents drying. As Bumpyroad said, it does not work well for mechanical connection of levers. And as DrewE said, you may want to attach the substrate first and then the filon. Attaching the Filon to the substrate first only works well if there are no curves as in it is a flat surface..
I built two clamping bands out of 10 ft. 2x4s to go around the camper. When I put the material in place, I put a sheet of plywood over it to cover the area being glued, then a couple of 2x4 on top of the plywood to distribute pressure and clamped it to the camper with Erwin hand clamps between the clamping bands and the 2xs on the plywood.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
