Hudsoner
Oct 20, 2016Explorer
AndyfromTucson wrote:
- Third step would be swinging the new panel out a bit, then getting under it and applying 3M 30NF Contact Adhesive (supposed to work on styrofoam) to the framing and styrofoam and the underside of the new panel, letting them dry per instructions, then pressing them together and using some sort of roller.
Any thoughts, corrections or advice?
I like your desire to use lots of 3M adhesives, because that helps to insure the continuation of my pension checks.
Just for heads up, the cross linking (curing) of the contact adhesive is initiated by the elimination of oxygen (happens when you press the two substrates together). The strength of the bonding depends a lot on the initial pressure applied to the two substrates to be bonded together. That means, the more initial pressure you are able to apply, the better the stuff sticks together in the long run.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
