DrewE
Oct 19, 2016Explorer III
Welding looks impossible to me without removing the foam etc. from the area. Welding involves a lot of heat.
I agree with Oasisbob that this probably isn't aluminum, at least gauging from the picture; it looks more like painted steel. Pictures can be deceiving, though. Aluminum doesn't rust, has a somewhat shiny gray surface, and is comparatively soft (many alloys can be cut or marred with woodworking tools). Welding aluminum is rather tricky work, I gather both because it is hard to keep clean (it oxidizes quite quickly on the surface) and because it has a very narrow plastic range between not joining together and forming a puddle of molten metal. I have absolutely no experience myself welding anything, though.
I might try a reinforcing plate and some JB-Weld (and mechanical fasteners). If there's any easy way to do so, I'd also inspect the same joint on the other side for the same problem.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
