Huntindog
Oct 21, 2016Explorer
Huntindog wrote:I was thinking of getting some beefy aluminum corner brackets and screwing or bolting them to the framing as an alternative to welding. Anyone have any experience with this?I don't think that would hold up.
If you want to reskin it with filon, I don't see an easy fix for this.
The aluminum tubing is pretty thin so any bolts, screws etc. will just either strip out, or crush it.
It needs to come apart more to clean up the metal and remove flamables from the area before welding.
If you are willing/able to reskin it with siding, then there are some other methods that could be used.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
