ken56
Oct 21, 2016Explorer
Someone mentioned if the weld on the bottom, where it was likely welded in the first place is broken. Its not unusual to have a small gap between pieces for welding expansion purposes. Look closer and confirm that it really is broken. TIG is the best way to repair it if it is broken and a skilled welder is required who has experience in aluminum. It must be squeaky clean to weld. No glue residue as it will just contaminate it and may not flow together well. Yes, I have done some welding and I never could get the hang of welding aluminum. Quite difficult.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
