I like this better. Two panels
Dimensions (inches): 43.54 x 26.22 x 1.38?, $175 the pair.
Here is the best part; Short Circuit Current (Isc): 6.30A.
In parallel this gives 12.6A which is more that the 180W panel. When shopping panels for a PWM controller,
the Isc rules. Ignore Watts. Panel Watts are calculated as Vmp * Imp.
If you do decide on solarblvd.com, match the labels on the panels to their website specs. If different, ask them to put them on a meter and put those readings on the sales slip. You want the most Isc/$.
HTH;
John
