full_mosey wrote:
Now that you mentioned MPPT, here are the salient points:
1. Watts do matter! This is different from the Isc/PWM situation.
2. With MPPT and a 200W panel and 14.4V charge, you calculate charge Amps as 200W/14.4V = 13.8A. If the MPPT is 96% efficient the result to the battery is 13.8 * .96=13.3A.
3. MPPT simplifies panel selection because it allows you to focus on fitting panel(s). You might want to look at 24V panels on solarblvd.com. You will be amazed at the $/W difference from 12V panels. This is where MPPT shines.
HTH;
John
You forgot that with MPPT you must first allow for panel heating, so knock 10% off the rated watts for that. Then something for line loss panel to controller. Now you have controller input watts. Then you deduct for controller efficiency. Now you have controller output watts. There should not be any line loss controller to battery but in some installations there will be. Now divide output watts by rising all day battery voltage and get your amps to the battery as they get less as battery voltage rises.
200w becomes 190w with panel heating, say 2% line loss so now at 186w input, 96% of that is 179w output
179/13.0 = 13.8 amps
179/13.5 = 13.3 amps
179/14.0 = 12.8 amps
179/14.4 = 12.3 amps
However once the batts are 14v it is very soon after they hit 14.x your Vabs and now you exit Bulk with its MPPT are now in Absorb doing PWM.
