MEXICOWANDERER wrote:
MAIN Engine battery
AUX House battery
GROUND Must be wired to the frame or body
Other two push on terminals are optional. Unit will work perfectly fine with them not wired up.
Put fuse or breaker close to engine battery connection. No less than 100 amps capacity.
Then mount the Sure Power and wire it up. Eight gauge wire.
The battery separator thinks for itself, no need to do anything more than verify it allows power to go from the alternator to the house battery. If the house battery charges -- it'll be charging correctly.
Great - thanks Mex - I appreciate it. Will plan to install Sunday and send pics.
L
