JohnnyGood's avatar
JohnnyGood
Advice on deep cycle setup?
Hello,
I have a Safari van that I've converted into a camper.
I replaced the starting battery with a Duracell Ultra Dual Purpose (Starting/Cycling) Battery that cost $105 (got it at batteries plus).
I'm running a multi-cooker (700 watts) with a 600 watt inverter (yes, I realize that there's a difference, but it seems to work fine (?).
I want to get another deep cycle house battery, as it seems to max out the battery after 5 minutes of use (the inverter starts beeping).
Does anyone have any suggestions on batteries to get, or how to rig this up? I'm a contractor and have some experience with electricity, but I don't understand all the ins and outs of a deep cycle power setup / battery power etc.'
I also want to get a heater installed for minimal use: http://www.my12voltstore.com/DC_Thermal_SA12_2000_12_Volt_Turbo_DC_Heater_p/sa12-2000.htm
Any tips welcome!
L
Replies have been turned off for this discussion
  • another duplicate battery will give you 10 minutes of use
    you need a generator
    or get a new heavy alternator and run the engine while using your cooker
  • You may do better by running heavier loads on a generator.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
