westend
Dec 25, 2013Explorer
KATOOM wrote:No risk at all. I believe 2oldman was referring to the LED not surviving the 14V a converter will put out when in it's bulk charging stage. This has been somewhat disproven as a couple of Forum members have tested the typical Asian LED panels and found that they survive at voltages up to 15V. I have not experienced a single failure. I know JiminDenver has had a panel hooked up at higher voltage for some time. Maybe he will post whether the panel is still surviving.
I'm curious what you guys are talking about in regards to the LED lights causing the convertor to put out more charge volts. :h Can someone elaborate on this? Is there some undisclosed risk with LED's and the batteries or charging system?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
