rferoni
Aug 25, 2014Explorer
Thank you all for the advice...
I guess I wasn't 100% clear explaining what I want to know.
I have access to two roof rafters which I will use to attach the new piece of wood with screws, so that part is not an issue. I need to know if I need to be concerned about the seam that will be created by butting two boards together. Over time the rubber roof laying over the seam seems like a bad idea. I was just going to use some sort of tape but wasn't sure what kind.
I see someone above mentioned using mesh tape and caulk. How exactly? I can see using mesh tape with some sort of dry-wall style mud but using caulk and mesh tape doesn't make sense to me.
Thanks,
Ron
Thanks,
Ron
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
