dougrainer
Jul 23, 2018Nomad
NO, You will have to drill out the rivets and release the spring tension to "clock" the camlock correctly. Question. The camlock, does it have Knurled splines or a gear tooth lock? IF NOT a Gearlock on that camlock you need to replace the complete RH torsion. Reinstalling a knurled Camlock will just fail shortly and unroll. Dometic changed the design of the Camlock years ago to a gear tooth design. Odds are when you installed the Torsion spring you got the camlock too close to one of the 3 awning fabric channels and it is hitting that. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
