BFL13 wrote:
I find the voltage sag under a load is the same for any SOC. It is the amps that does it.
Ahh, then we shouldn't have any problem. Thanks.
Our Kisae is the 2420 model, for nominal 24V batteries (<3% THD and 11.5 lbs), but the 12V model should be similar.
The low voltage warning is at 22.4V, the LV cutoff is 21V
If 24.0V represents 50% SOC for our 4 GC2s in series, then I can have a 3V drop before cutoff, and 1.6V drop before warning. So far, the max drop I've seen is 1.2V at about 1000W when boiling water. Our microwave is 1200W so that'll be higher, but haven't checked it.
