Krusty
Aug 12, 2021Nomad II
Can you use your meter to determine if the fault is on the power side or the ground side? If power side, I think the wiring harness travels up the LH frame rail to the front and there should be a few inline connectors under the hood, above the LH front fender. Make sure these connectors are connected securely with no corrosion.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
