groundhogy's avatar
groundhogy
After towing RV with bad batteries, truck blinkers...
... and brake lights doing weird stuff.
Turn signals act like a light is burned out. They blink real fast. Both sides.
Sometimes they blink a little slower, then pick up speed.
If blinker is on, and then you brake also, the blinker freezes up and stops blinking.
If you go behind the vehicle, the turn signal and brake lights can be seen, but are dim.
  • jdc1's avatar
    jdc1
    Explorer II
    wa8yxm wrote:
    Bad ground connection on lights or between tow vehicle and trailer
    And check your FRONT turn signals.
  • clarify all this...
    You say, after. Do you mean after towing and after unhooking and then driving the truck with no trailer then things do this, or it does it when hooked up?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
