pnichols
Jan 10, 2021Explorer II
agesilaus wrote:
MIGO TMI..heh. He packs so much tech data in so fast it's impossible to evaluate. And I am a tech tho not of the electrical variety. One thing I fished out of the flood was that the cheap 6V golf cart batteries were the most cost efficient. Strange that he didn't include Trojans or another high quality brand into the test. He then launches into the life cycle cost analysis. That's where I gave up. I have to admit that I have suspicions that this fellow is in the pocket of Battleborn. The info about 6V batteries was inserted in a very fleeting manner, almost as if he was hiding it.
As for life cycle I will admit that if you keep your RV for 20 years or so then yes, Lithiums may pay for themselves. But most of us will not. And even if you have to replace your 6V battery pack once or twice over your time in the RV the costs will never approach the $4000 LiB battery pack price.
I have never been a fan of AGM, they are designed to start a vehicle not store energy. Golf cart batteries are designed to store power and so are the LiB.
So I'll stick with 6V unless the price of LiB plummets. Something I doubt will happen because of the scarcity of lithium.
Of course ... you know that AGM batteries in 6V golf cart sizes for true deep cycle use are available? These 6V type/size AGM batteries definitely are not intended for vehicle starting.
The 12V AGM batteries in our MH also have nothing to do with vehicle starting - they are labeled and specified to be specifically intended for deep cycle applications. They also charge fast because of their low internal resistance.
FWIW, lithium batteries are noted for holding a higher terminal voltage right down to their total discharge point. This is not always a good thing, as this can be a problem for knowing how much charge they have left because it's more complicated to tell when they're getting low - unless they're monitored with equipment that keeps track of current consumed versus time while in use. i.e. For the AGM batteries in our MH, I just check their terminal voltage with a simple, inexpensive digital voltmeter in order to tell how low in charge they are.
