MEXICOWANDERER
Apr 24, 2014Explorer
Two hundred cycles at 100% discharged with 40% capacity remaining as the cut off limit for number of cycles isn't bad. AGM's due to their -inherent- self control of total discharge limit are far less susceptible to self-destruction than a standard flooded lead acid battery.
If you can live with the cost of replacing the battery after 200 cycles*, then this one is a consideration.
*And having the total capacity degrade from 18 amp hours to 40% of that during it's lifespan. A 7 something amp hour battery is not exciting. A D alkaline cell is around the same so 8 fresh D alkaline cells will have the same energy storage as this battery would after this battery is used 200 full discharged cycles.
