greenrvgreen
Apr 28, 2014Explorer
If it's not too late, I'd like the group's thoughts on this:
http://www.goalzero.com/p/164/goal-zero-yeti-150-solar-generator/22:2/#tech-specs
The is the Goal Zero Yeti 150, which is battery (14ah) + inverter (80w MSW) + charger + 12v 10a output. Expensive, yes, but is it "overpriced"? Currently I'm likie for the convenience factor, and it's about the same amount I'll have to spend on separate items.
Downside: while the battery is swappable, if you want to leapfrog (alternate) charge your batts you have to buy 2 of these, or else a separate charger.
