DryCamper11's avatar
DryCamper11
AGM batteries - are they better?
Upgrade to an AGM battery. You can safely mount them inside, and upside down, and they will out-perform any flooded battery you ever owned!
Here's a quote from another thread. It's typical of others I've seen. I wonder if anyone here can convince me it's correct. Clearly the AGM has some advantages. Two are seen in that quote - inside and upside down. If you need to mount upside down and can't ventilate, sure, that's an advantage, but I don't need those advantages and don't want to pay extra for something I don't need.
We're left with the rapid charge rate they are reputed to permit. I would love to run my 80A charger at 80A continuously until I reach 100% SOC. Right now my 460AH FLA batteries recharge at 80A from 50% SOC for about 3 hours (some fluctuation in current - slow climb from below 80 to above 80 during the first hour as they warm up then down to 70+ at the third hour), then begin to taper more rapidly during the last hour as the battery voltage approaches the charger voltage.
Does anyone have charge curves for AGM showing the performance (preferably with an 80A charger)? I'd particularly like to see the tail end of the charge cycle. How do AGMs perform? Is it significantly better than FLA batteries? Do AGMs taper the charge rate the way FLAs do, or is the entire advantage in the fact that I could run a bigger charger (100+ A) for my 460AH battery bank?
Are there other advantages that AGMs offer?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
