time2roll
Oct 28, 2013Nomad
DryCamper11 wrote:smkettner wrote:
Superior charging speed
Let's work through these. The charging speed is what attracts me. But I can't determine if it's real. Sure, I can recharge faster below 80%, but I need to recharge faster above 80% SOC, which is where all my recharging is currently done.
The AGM lower internal resistance allows faster charging at all levels.
I hesitate to quantify this but WAG 20% to 50% faster.
Also AGM will tend to handle higher discharge rates and might support a larger inverter with less amp hours. Especially conpared to GC2.
Also rests at a higher voltage so along with more amps should prove to be a superior starting battery if you have a cold diesel. Sears Platinum is king of CCA.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
