CA_Traveler
Oct 28, 2013Explorer III
Partial comparison:
Lifeline GPL-4CT 220AH 66lb 10.28x7.05x9.92H $316
Interstate GC2-HD-UTL 216AH 64lb 10.25x7.12x10.85 $149
Interstate GC2-XHD-UTL 232AH 65lb 10.25x7.12x11.25 $153
Virtually the same except for cost.
OP It doesn't seem like AGMs are for you as for most RVs, which is likely the cost factor.
I don't know of any RV that has a 500A charger. I suspect telcoms want a very fast rate when power is restored and may use very high charge rates.
Generally for my AGMs charging is about the same profile rate as a flooded battery. It is a different profile but not to far different. My 100A Magnum generally charges at a maximum of 80A due to design cost tradeoffs and I haven't measured my alternator charge rate but suspect it's about the same.
All of this makes me wonder why Monaco installed AGMs in my rig. They are outside and the higher GC2 height is not a factor. Less self discharge, lower internal resistance, better voltage regulation, no corrosion, no checking/adding water, what?
Mex, Want to hazzard a guess?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
