christopherglen
Oct 28, 2013Explorer
I run 3 agm's - ~255 ah with a 150 amp inverter/charger. It charges 150-160 amps at the start of Bulk, dropping to 40-60 amps for Absorption for ~30 minutes, before dropping to float. Absorption to <10 amps in float is less then an hour. The biggest bang is the 150 amps in bulk, with your 80 amp charger, I doubt you will see anything but a lighter wallet. In your case I would out a solar panel or two on the roof for the end of the Absorption stage and call it good.
I run them on my rig because the inverter is 3kw, with a 6kw surge - That would talk a lot more then 255 AH of wet cells to support. My agm's are rated for 5C charge - with a big enough power source I could shove over 1200 amps into the batteries (for a few minutes until they taper). Not really useful, but at 150 amps I am not even starting to challenge them.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
