BFL13
Oct 28, 2013Explorer II
Ignoring all questions of why in the world you would want to operate in the 80-100 SOC zone where you have such slow charging AGMs or Wets, which is why people do 50-80s instead, then:
To get higher amps for shorter time in the 80-100 SOC zone, you need a higher absorption voltage (within reason)
Might be easier to get a charger with a higher Vabs than the existing 80amper than to go AGM even if they would charge a little faster.
AFAIK from previous threads, AGMs taper the same as Wets during the Absorption Stage.
To get a 14.8v Vabs for my 458AH bank of four wet 6s, I set 15v on the charger. ( A PowerMax 100amper with adjustable voltage) I do a 50-90 in about two hours and ten minutes.
It takes about 50 minutes to do the 80-90 part with amps tapering from about 60a to about 20a in that time (I call 5 amps per 110AH 90% as when to stop the gen)
If you want faster charging for the 50-80 part than the 80 will do just buy a VEC1093DBD and add it on for 120a initial charging. 460AH bank accepts that no problem (unless the gen can't run that much)
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
